Save part from assembly with assembly features
Question asked by Jacob Brunson on Jan 27, 2016
Latest reply on Dec 22, 2017 by Glenn Schroeder
I have several parts that are 1"x1" square aluminum tubing extrusions of various lengths.
I have an assembly where I insert multiple of these aluminum parts and then attach them together with steel brackets.
I use the Hole Wizard to create holes which go through the steel brackets and the aluminum extrusions. I will insert bolts into the holes in order to fasten the pieces together.
The holes in the aluminum extrusion exist only as assembly features (i.e. the parts alone have no holes). Is there a way for me to save each modified part with the holes included?
The goal is to produce a .dxf file of each of the modified aluminum tubes containing the assembly holes.
Any guidance would be appreciated. Thanks!
