I have been able to make circular patterns of all my previous features but when I try to do the same for the wrap and swept cuts features the circular pattern feature denies me from doing so. I don't know what I'm doing wrong and Solidworks doesn't tell me. Thank you.
Hello Edward... You are correct SW won't let you do a circular pattern on the cut sweep with guide curves. I learned something too. I noticed that if I removed the guide curves and did the circular pattern with the "Geometry" option it did work. I did this a couple of other ways using "Cut-Thicken" and also Swept Boss (not merge-circular pattern using bodies) and then "Combine/Subtract". I noticed that if you zoom in close on your file you will see that the swept cut with the guide curve goes a bit squirrely.
See if this works for you. You do get a slightly different look at the groove transitions but you don't have the squirrely thing going on.
