I'm trying to convert this surface model into a solid. I managed to get it down to 1 surface, and it looks to me as if I should be able to "try form solid" under knit surfaces however this doesn't work and I'm having difficulties understanding why I can't make it into a solid.
I've attached the part in question for you to have a look at as I am stumped. Any help would be greatly appreciated.
Dan.
Doesn't look manifold.....
The front half is OK, behind the side windows there's something wrong. When you look at the contourline there is a small gap between the blue (selected line and the black (unselected) one.... When I export it to for example netfabb (nice program for fixing up holes) there are also possible some problem areas around the lower sides of the backlights (I must admit this is via a STL file export, this is rather crude). Solidworks on itself is (in my opinion at least) not the holy grail when you are modeling these kinds of things. I had a lot of trouble also when modeling the nose green house of my scale B25 airplane.... :-)
