I had a sub-assembly which was called:
Linear Outfeed Stage GA.sldasm
I needed it to be renamed:
MCP0178-005.sldasm
I therefore made sure I owned the assembly, and the top level assembly it is used in, and even the components making up the assembly.
I right-clicked the assembly and selected 'Rename'. Sure enough, the Rename appeared to occur.
When I looked more closely at the vault, however, the assembly is shown as:
MCP0178-005.sldasm <Linear Outfeed Stage GA>
Curious...
I deleted every trace of the top level assembly from my local hard drive and checked out the top level assembly again. Sure enough, there is no file in the target directory called
'Linear Outfeed Stage GA.sldasm'
but there is a file called
MCP0178-005.sldasm
This is looking good.
I opened the top level assembly in Solidworks
Imagine my surprise when, nestling snugly in the Model Tree, I saw a sub-assembly called
when, according to Windows Explorer, there is no file of this name in the directory.
What am I doing wrong?
Why won't this wretched PDM(ish) system just rename the file I want to rename to the name I want it to have?
Software: SW2014 SP5
Tether: end almost reached
John
I'm guessing the file is somewhere on your local machine, just not where you think it was.
With the assembly open, select;
File>
Find References
Do you see any clues?
