0 Replies Latest reply on Jan 25, 2016 6:44 PM by Rick Hombsch
    Auto-Run Macro leading to system being in unstable state message
    Rick Hombsch
      I am trying to auto-run an embedded macro as shown here:
      http://www.cadsharp.com/blog/equation-triggered-macros/
      The macro is used to modify design table values based on custom property inputs. The macro runs and updates the design table as needed however I get the following error (see below). Also sometimes I may get a corrupted design table. The macro I am running is shown below and only runs when the RunMacro custom property is 0. Attached is a simplied version of what I am trying to do however the premise is the same.
      Dim valOut   As String
      Dim resolvedValOut      As String
      Dim swDesignTable As SldWorks.DesignTable
      Dim CellValue As String
      Dim boolstatus As Boolean
      Set swModel = swApp.ActiveDoc
      Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
      'RebuildMacro Variable Used to Only run code on first rebuild
      swCustPropMgr.Get2 "RebuildMacro", valOut, resolvedValOut
      MacroRunValue = valOut
      'Get Length Width Height
      swCustPropMgr.Get2 "LENGTH", valOut, resolvedValOut
      Length = valOut
      swCustPropMgr.Get2 "WIDTH", valOut, resolvedValOut
      Width1 = valOut
      swCustPropMgr.Get2 "HEIGHT", valOut, resolvedValOut
      Height = valOut
      'If the model is rebuilt for the first time (MacroRunValue = 0)
      If MacroRunValue = 0 Then
      'Get Design Table
      Set swDesignTable = swModel.GetDesignTable
      'Edit Design Table
      swDesignTable.EditTable
      'Changes the first data row second colum to the cell value
      swDesignTable.SetEntryValue 1, 0, False, Length
      swDesignTable.SetEntryValue 1, 1, False, Width1
      swDesignTable.SetEntryValue 1, 2, False, Height
      'Update Design Table
      boolstatus = swDesignTable.UpdateTable(SwConst.swDesignTableUpdateOptions_e.swUpdateDesignTableAll, True)
      'Set RebuildMacro Custom Property to 1 so macro does not run again
      swCustPropMgr.Set "RebuildMacro", 1
