HAHrituc Alexandru25/01/2016
I want to sort component from design tree, and if found a folder to ignore it...
From example i have this:
After i run the macro, obtain this:
Why all components are inserted in folder????? inside the folder are sorted correctly, but useless...
How can write so if find a folder to ignore it????...and obtain this:
THANKS
this is the code i use:
Option Explicit
Dim Part As ModelDoc2
Dim swAssyDoc As AssemblyDoc
Dim selMgr As SelectionMgr
Dim boolstatus As Boolean
Dim source As Object
Dim target As Object
Dim components As Variant
Dim swComp As Component2
Dim nComponents As Integer
Dim sArray() As String
Dim iArray() As Integer
Dim i As Integer
Dim x As Integer
Dim y As Integer
Dim sTemp As String
Dim iTemp As Integer
Set Part = swApp.ActiveDoc
Set swAssyDoc = Part
Set selMgr = Part.SelectionManager
' Get all the top level components
components = swAssyDoc.GetComponents(True)
' Get the upper bound of  array of components
nComponents = UBound(components)
ReDim sArray(nComponents)
ReDim iArray(nComponents)
' Add component name and index to arrays
For i = 0 To nComponents
    Set swComp = components(i)
    sArray(i) = swComp.Name2
    iArray(i) = i
Next i
' Do a bubble sort on the arrays
For x = 0 To (nComponents - 1)
    For y = (x + 1) To nComponents
        If sArray(x) > sArray(y) Then
            sTemp = sArray(x)
            iTemp = iArray(x)
            sArray(x) = sArray(y)
            iArray(x) = iArray(y)
            sArray(y) = sTemp
            iArray(y) = iTemp
    Next y
Next x
' Reorder the components in reverse order
For i = (nComponents - 1) To 0 Step -1
    boolstatus = swAssyDoc.ReorderComponents(components(iArray(i)), components(iArray(i + 1)), swReorderComponents_Before)
Next i
