Hi
I am beginner in composer . Can anyone help me how to insert 2 view (like 3 standard view in Drawing ) in composer . Now i have one view in area and want to have 2 view .
Hi
Hi Adel,
do you want all 3 standard views in 1 view, or you can work with different views ?
Regards
Rohit
Adel, unfortunately, composer doesn't have this type of facility present in SolidWorks.
If the purpose is only arranging display of the component, then you can try changing the layout option to 4 panes. See if it can help you.
Regards
Rohit
One thing you could do is:
You should now find in your assembly tree in Composer that the file with the 3 instances is available, and you can turn them on and display them all at once.
Tip on updating:
If you find later that you need to update your assembly; (maybe import updated metadata or a change of parts), I've found the fastest way is to
I realize that sounds like a lot of clicks and steps, but when it comes to larger CAD files, I've found this workflow faster than the Update method where Composer opens SolidWorks and uses the *SLDASM file to update your *smg.
Tip on updating:
