Does a tool exist for creating a center line at the arc slot at the drawing?
Please see pic attached.
Hello
please select center mark command in annotation tab
in property manager window select (arc slot ends)
and then select slot in graphic area . you can see the result
Thank you,
It is working.
I had my Center Mark window with For all holes checked.
It closes slot option then.
Taghi,
Is it possible to dimension this central arc slot line?
Mine does not work.
Hi
click on center line . in property manager , unchecked the use document defaults
i think it is okey and work properly
Yes, it works.
Thank you for valued advises!
Hello
