4 Replies Latest reply on Jan 22, 2016 5:54 PM by Justin Sokel
    How can I incorporate a triangular flagnote into a list of notes that use a numbering paragraph format?
    Justin Sokel
      I'm having problems using triangular flagnotes when also trying to use the indent, numbering, paragraph spacing, and line spacing properties (all within the paragraph properties) for text contained in note annotations.
      The minor issue is that the numbers and flagnote numbers aren't aligned vertically, but that is okay since the indent can accommodate this.
      The major issue is that numbering functionality is lost.  If I insert a flagnote for note 10, the next numbered note will also be 10.
      Is there a way to "toggle" flagnotes for specific numbers on and off?
