Have you ever seen something like this?
It works if you neglect the icons but is odd.
Hi Tateos,
I think it is a intended behaviour, since you might want to copy but not with all mates.
So if you click on the icon you can deselect this mate from copying.
Cheers!
Leszek
Could be a graphics glitch. Restart SW and that should fix it.
Thanks for your thoughts.
This happens on the company's PC with SW2014 SP5.
I'll check it again on Monday and will post the result.
After the restart, nothing changed. Still the same odd behavior - the icon doesn't match the text.
I tried with a different selection, but it's still strange.
Appears correct for me. So could be a bad install on your side.
Either try reinstall OR create an Rx and send to your VAR.
Hi Tateos,
Cheers!
Leszek
