Hello All,
I upgraded from SW2015 to SW2016 this morning after pushing off the upgrade for several months due to concerns of always having problems with customized settings, etc that come along with a software upgrade. I got most of my settings & toolbars back to the way (I think) they used to be. One is baffling me though. When I installed SW2015, I had it set so that any part that I would create from scratch would automatically have certain properties preset to show on screen and all I would have to do is fill the blanks (see first pic below). Now with the new version, it shows up blank and I have to hit the drop down arrow and populate the box with each property I normally use (see pics 2 and 3 below) How is it done so that they will automatically show again? Thanks in advance!
I'm thinking that your templates need to be refreshed and made sure that all the information is the same from 2015 to 2016 - In the past I've seen that change when upgrading. In other words here I have all my templates on our server, not in my C drive. Then when a new version gets loaded, it should do a clean un-install and a clean install, then the directories or file locations change, not sure if that is your issue or not, but that is where I would start checking...
Just another reason why I made my own revision blocks - if that would happen here, I'd be looking for a cliff...... I'm sure you'll get it back up and running the way you want it..
