I'm mounting a component of hardware on an angled base. I want the angled top of the base to match the component's footprint, but I want to draft the base outward so that its bottom is wider than its top. I thought I could do this with a path sketch on the angled top surface and a sketched trapezoid as the cutting profile. When I sweep the profile around the path, I want it to rotate to follow the path, but not twist (In other words, it should remain perpendicular to the Top Plane as it travels along the path). I don't see any settings that will let me do this. Is there a way?
The part is enclosed. Sketch 19 is the path, Sketch 20 is the profile. Any ideas? Thanks all.
Have you tried a direction vector in options?
