Hi everyone,
I am simulating an inverter cooling with axial fans. Does anyone know how to vary RPM of a fan in Solidworks Flow Simulation? Because I want to see the effect of fan static pressure to thermal behavior of the cooling.
I have tried changing the rotor speed (rad/s), which is corresponding to RPM, but to no avail. Let's say I use Papst 8412N fan, the default rpm is 3600 rpm. I have varied the rpm from 3600 to 50 rpm, but the results are similar.
Your suggestions are highly appreciated.
Hans
How are you gaging the effects of the fan's RPM? Are you looking at the velocity of the wake?
