Hello All,
I am looking for some help with the attached part. It is a lofted sheetmetal part and I cannot get one of the bend lines to take so to speak. I have an equal amount of vertices and as far as I can tell I have done everything properly but I cannot for the life of me get the last form line to generate. This is causing none of my bend lines to show when projecting a flat pattern.
I have been on this part for the past 10 hours and would surely appreciate any help you all can offer.
Thank you in advance,
Tony
I think I have this figured out Tony... The reason the bend lines weren't showing in your file is there is a twist in two areas of the loft. Non planer surfaces. What I did in my attached file is deleted some of your in-context relations in your profile (on one end) and made parallel relations to the corresponding lines on the opposite end profile. This altered the geometry slightly in two areas. See screenshot. Everything else matches up perfectly. I have attached an assembly file with 3 parts. Your original (not altered), An altered "formed" and an altered "bent". The altered "formed" has a Loft minimum (that's what SW does on formed lofts) of 2 bend lines for each bend. I suspect you could put the bend line midway between them. The one done with the bent option just has a single line per bend and no reliefs as in the previous one. In the screenshot the original is grey, Altered formed is rust and the altered bent is yellow.
I think this is what you were hoping to see.
