Error with digis decimal precision in macro solidworks
Question asked by Tuan Hoang on Jan 19, 2016
Latest reply on Jan 19, 2016 by Tuan Hoang
Hello, I'm new with vba in solidworks, I tried with the following code and it run well. Unfortunately, when I change the red number from 1 to 0.1 or 0.001 for example, it doesn't work anymore.
So, anyone can help me to treat thi problem ?
Thank you.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Plan de face", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
Part.ClearSelection2 True
Dim vSkLines As Variant
vSkLines = Part.SketchManager.CreateCornerRectangle(-20, -20, -20, 20, 20, 20)
Part.ShowNamedView2 "*Trimétrique", 8
boolstatus = Part.Extension.SelectByID2("Line2", "SKETCHSEGMENT", 0, 0, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Line1", "SKETCHSEGMENT", 0, 0, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Line4", "SKETCHSEGMENT", 0, 0, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Line3", "SKETCHSEGMENT", 0, 0, 0, True, 0, Nothing, 0)
Dim myFeature As Object
Set myFeature = Part.FeatureManager.FeatureExtrusion2(False, False, False, 0, 0, 20, 20, False, False, False, False, 1.74532925199433E-02, 1.74532925199433E-02, False, False, False, False, True, True, True, 0, 0, False)
Part.SelectionManager.EnableContourSelection = False
Part.SketchManager.Insert3DSketch True
Dim skSegment1a As Object
Set skSegment1a = Part.SketchManager.CreateLine(-51.2793, -61.6772, -38.2916, 55.7814, 38.1473, 26.3077)
Part.SetPickMode
boolstatus = Part.Extension.SelectByID2("Line1@Esquisse3D1", "EXTSKETCHSEGMENT", 55.7814, 38.1473, 26.3077, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Point1@Esquisse3D1", "EXTSKETCHPOINT", -51.2793, -61.6772, -38.2916, True, 1, Nothing, 0)
Dim myRefPlane1 As Object
Set myRefPlane1 = Part.FeatureManager.InsertRefPlane(2, 0.002, 4, 0, 0, 0)
boolstatus = Part.Extension.SelectByID2("Plan1", "PLANE", -4.80394589232693E-02, 2.05838674226015E-02, 3.00484425104059E-02, False, 0, Nothing, 0)
Dim skSegment1b As Object
Set skSegment1b = Part.SketchManager.CreateCircle(0, 0, 0, 1, 0, 0)
Set myFeature = Part.FeatureManager.FeatureCut3(True, False, True, 1, 0, 50, 50, False, False, False, False, 1.74532925199433E-02, 1.74532925199433E-02, False, False, False, False, False, True, True, True, True, False, 0, 0, False)
Part.BlankRefGeom
boolstatus = Part.Extension.SelectByID2("Line1@Esquisse3D1", "EXTSKETCHSEGMENT", -4.96918629056041E-02, 2.31034739947416E-02, 3.96719923841123E-03, False, 0, Nothing, 0)
Part.BlankSketch
