In Heat Exchanger, Steam and Water are used and Not in same area/mixing. I am aware, Flow could not handle Phase change, Evaporation & droplets;
Was trying to assign pre-defined Steam from material lib. and dint work, any suggestions.
Regards,
AJ
Good morning Ajay,
Your question is very vague, we can't really help you much when all we know is "it doesn't work." Can you please be more specific? What are the error messages? Where are you having trouble exactly? Are you using fluid subdomains for the separate fluids?
