When I run the thermal simulation at 200 °C with ABS plastic, it should've melted, or at least deformed. However, when I run the simulation, it says that there is no deformation. What did I do wrong and what should I do?
Nice reference. I almost got it, but the only thing that the simulation doesn't work is where it says "Thermal Expansion Coefficient (Alphx) is not defined for element 1. Check material" even though I already set it as ABS plastic. I don't get how to set the coefficient etc.
You would have to create a custom material in your custom folder, you could copy the standard material and paste it in the custom folder and it will let you fill in that property. The thermal expansion coefficient is going to be very specific to the material that you are using. I take most of my information from www.matweb.com and it gives a very large range depending on what you are using. This is what it shows for ABS molded.
Seeing from the screenshots that htis is a thermal only study, deforamations/displacements are not solved for. The only unknowns being solved are the equivalent of displacements: temperatures. And so gravity is not considered. However, convective losses are considered and you need to apply convective heat transfer to the surfaces that are in contact with whatever fluid medium this item would be in contact. (I use engineering.com's toolbox for some generic heat transfer coefficients between solids and fluids)
Once your thermal study runs then you can couple the results to a static simulation and get your developed stresses and displacements.
Please upload the model. I think you have not setup the study correct.
Janko Stellaard
Cadmes BV
The Netherlands
