I created the drawing using the custom (not default) template.
When I add the new sheet to my drawing it is based on default template, not the used one.
Please advise it is normal behavior?
I hope I would have at least a chance to chose the template I am up to add.
Save sheet format from your custom template and the map here
In case you want option to select different sheet format, select this option
You may also set this option for the second or new sheets.
