2 Replies Latest reply on Jan 18, 2016 9:15 AM by Ethan Thompson
    Is it possible to insert parts or sub-assemblies into an assembly and have it also make a cut?
    Ethan Thompson
      I am wondering if it is possible to insert a sub-assembly (such as a door latch with screws) into an higher assembly (the door) and have it make the necessary cuts for you (e.g. a recessed rectangular cut for the plate, and two holes for the screws. See pic below as an example.)
      I am hoping that I can drag in a sub-assembly, locate it, and then have it make any necessary cuts.
      Thanks for any advice,
      Ethan
