Recently at worked we have started in house fabrication, as such our k factors need changing to suit our press brake. However, after doing test pieces the flat pattern length is still not correct. All flat lengths are correct for one bend but not multiple bends.
I modelled a part with 4 bends and the flat length is 4mm too short. To gain this extra 4mm the k factor needs to be set to 0.7, does this seem right? I thought k factor should be 0.25-0.5 due to extending ratio etc etc. I've never needed to calculate k factors, and attempted to use bend deductions but with little sucess, any advice
K-factors can be very accurate, assuming you use good data. The biggest mistake I have seen is assuming values for material thicknesses and bend radii instead of measuring them. The attached pdf explains K-factors and how to calculate them and the attached spreadsheet makes the calcs easy. We went so far as to measure coupons bent with each gauge and bend radius combination and then created a table of K-factors specifically for our shop.
