When I dimension a part sketch I left click on a line (as example) and than drag a dim out and left click again.
On the second click I have no dimension property window.
To change the dimension I need to double click dimension twice to access the dim property window, please see pic attached.
Please advise is there a setting to pop up the dimension property window on the second click or it the way the SolidWorks is working?
Go to: System Options -> General -> and make sure you have the first option on top slected 'input dimension value'
