Hi everybody.
I got a trouble with shell command being unable to shell with a bigger thickness than thickness of a feature in solid (PTT Button). but I saw it's able to set 1.5 mm (shell command) in the other file (PA0117030A PTT BUTTON). Can somebody explain to me ? Thank you in advance.
The boss extrude 3 feature is only 1.2 mm and hence the error.
Check if this is what you need
