Sets the diameter for the dimension corresponding to the entity type with the cosmetic thread.
Now set diameter methor change Parameter value.
Set SwDim = SwModel.Parameter("D2@Cosmetic Thread1")
Debug.Print SwDim.FullName, SwDim.Value
Help, How to change diameter of cosmetic thread.?
Follow code is traverse feature, obtain dimenion.
Private Sub ll()
Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
Set SwApp = Application.SldWorks
Set SwModel = SwApp.ActiveDoc
Dim SwFeat As Feature, SwSubFeat As Feature
Set SwFeat = SwModel.FirstFeature
Do While Not SwFeat Is Nothing
'Debug.Print SwFeat.Name
Set SwSubFeat = SwFeat.GetFirstSubFeature
Do While Not SwSubFeat Is Nothing
'Debug.Print SwSubFeat.Name
retuDispDim SwSubFeat
Set SwSubFeat = SwSubFeat.GetNextSubFeature
Loop
Set SwFeat = SwFeat.GetNextFeature
Loop
Function retuDispDim(SwFeat As Feature)
Dim SwDispDim As DisplayDimension, SwDim As Dimension
Set SwDispDim = SwFeat.GetFirstDisplayDimension
Do While Not SwDispDim Is Nothing
Set SwDim = SwDispDim.GetDimension
With SwDim
Debug.Print .FullName, .Value
End With
Set SwDispDim = SwFeat.GetNextDisplayDimension(SwDispDim)
Loop
End Function
Result is
S@Sketch1@Nut.Part 30
D@Sketch1@Nut.Part 20
D2@Cosmetic Thread1@Nut.Part 25
D1@Sketch3@Nut.Part 18
D2@Sketch3@Nut.Part 30
D1@Sketch4@Nut.Part 18
D2@Sketch4@Nut.Part 30
