12 Replies Latest reply on Jan 26, 2016 10:23 AM by Andreas Killer
    Custom Property Conversion Macro help
    Anton Miller
      All,
      We are currently converting all of our custom properties to new names.
      for example Part_number is now to be DWGNUMBER1
      I'm hoping there is an easy way to write a macro to copy the values in the old properties and add them to the new properties.  Also I wish to not delete the old properties incase of any reason we need to use our legacy templates.  The properties do not need to be linked, just copied and pasted.
      Thank you for your time and help!
      Anton Miller
        • Re: Custom Property Conversion Macro help
          Andreas Killer
          Hi Anton,
          customize the vOldNames and vNewNames arrays for your needs, open the template and run the macro.
          Andreas.
          Sub CopyProperties()
            Dim CusPropMgr As SldWorks.CustomPropertyManager
            Dim AddStatus As swCustomInfoAddResult_e
            Dim i As Long, j As Long, k As Long
            Dim vOldNames, vNewNames
            Dim vPropNames, Value, Typ
            Set swModel = swApp.ActiveDoc
            Set CusPropMgr = swModel.Extension.CustomPropertyManager("")
            'Define arrays with the old and new names
            vOldNames = Array("Material", "Part_number")
            vNewNames = Array("DWGMAT", "DWGNUMBER1")
            'Get all properties
            vPropNames = CusPropMgr.GetNames
            For i = LBound(vPropNames) To UBound(vPropNames)
              Value = CusPropMgr.Get(vPropNames(i))
              Typ = CusPropMgr.GetType2(vPropNames(i))
              Debug.Print vPropNames(i)
              'Search for the old names
              For j = LBound(vOldNames) To UBound(vOldNames)
                If StrComp(vPropNames(i), vOldNames(j), vbTextCompare) = 0 Then Exit For
              Next
              'Found?
              If j <= UBound(vOldNames) Then
                'Already exists?
                For k = LBound(vPropNames) To UBound(vPropNames)
                  If StrComp(vPropNames(k), vNewNames(j), vbTextCompare) = 0 Then Exit For
                Next
                If k > UBound(vPropNames) Then
                  'Add the new one
                  AddStatus = CusPropMgr.Add3(vNewNames(j), Typ, Value, True)
                  If AddStatus <> swCustomInfoAddResult_AddedOrChanged Then
                    'Error: Not added!
                    Err.Raise AddStatus
                Else
                  'Already exists
            Next
              Anton Miller
              Thank you very much!  this will save us a lot of time.
                Anton Miller
                Andreas,
                Can you give me some help on how I could modify this to open all parts and assemblies in a specific folder and have this macro run?
                I have tried many of the ways shown on these forums and it has not worked
                Thanks for your time!
                Anton
                    Ivana Kolin
                    Anton, if you want to use it for many files, then use Document manager. It is much faster.
                    2015 SOLIDWORKS API Help - Getting Started
                      Viktor Bovzdarenko
                      If you want to open all parts and assemblies in a specific folder and have this macro run then you can try: #TASK
                      Drag your folder or parts, drag macro, filter for which files to run macro ("sldprt" for this macro) and press "Run Job". Each part will be opened and macro will be applied.
                      If the folder have thousands of parts then solidworks will restart every 50 files (or as you specify). This will speed up the process. Also SolidWorks will start again if it crashed for any reason.
                      It is a Beta version of #Task. Central Innovation takes no responsibility of any loss or damage incurred through the use of #TASK. So please, back up your data if you haven’t done so already before running #TASK.
                        Andreas Killer
                        Hi Anton,
                        I suggest not to modify the macro, write a 2nd one as shell which opens the files. Code below is not tested!
                        Andreas.
                        Sub OpenFiles()
                          Dim FileError As Long
                          Dim FileWarning As Long
                          Dim nDocType As Long
                          Dim Path As String, FName As String
                          Dim Extension As Variant
                          'Setup the path (customize this)
                          Path = "Z:\temp\"
                          'Which kind of file? (customize this)
                          Extension = "sldprt"
                          Select Case LCase(Extension)
                            Case "sldprt"
                              nDocType = swDocPART
                            Case "sldasm"
                              nDocType = swDocASSEMBLY
                            Case "slddrw"
                              nDocType = swDocDRAWING
                            Case Else
                              MsgBox "Unknown extension"
                              Exit Sub
                          End Select
                          'Refer to Solidworks
                          'Find the 1st file
                          FName = Dir(Path & "*." & Extension)
                          'Found?
                          Do While FName <> ""
                            'Open the file
                            Set swModel = swApp.OpenDoc6(Path & FName, nDocType, swOpenDocOptions_Silent, "", FileError, FileWarning)
                            'Call the other macro
                            CopyProperties
                            'Close the file
                            swApp.QuitDoc swModel.GetTitle
                            'Find the next file
                            FName = Dir
                          Loop
                            Anton Miller
                            you're brilliant!
                            this is working out extremely well and I thank you very much.  I am on my final round of testing before I go live with this and run on all of our release files.
                            I am running into an error every now and then when the model doesn't have custom properties at all.
                            It fails here:
                            'Get all properties
                                Next
                            I have been learning a lot over the past week about this programming stuff, but I am still very new, but is there a way to put an argument in the get all properties section to say if no properties then end?
                                Viktor Bovzdarenko
                                Should start "For" loop if it has some values
                                for instance: If Not IsEmpty(vPropNames ) Then
                                Try applying this before each loop
                                If Not IsEmpty(vOldNames) Then
                                    Next
                                Next
                                    Anton Miller
                                    Thanks viktor!
                                    This does work.  but I did find a slightly better way for our applications as I need to link a new description property to our new Title1, title2, title3
                                    This is the code I have patched together by using some other examples ive found.  so what I did was added the property description, to be sure it exists then I delete it (cause i couldn't find a way to get the input value to overwrite if anything is there) then add the linking code.  it is working on files from 100- 150 QTY.  but when I try it on around 800 files it does not add the $prp"title2" $prp"title3"  only the title 1 links.
                                    do you see anything that could be causing this?
                                      vOldNames = Array("PART_NAME", "Part_number", "FOR", "DATE", "DRAWN_BY", "CHECKED_BY", "NEXT_ASSEMBLY", "REVISION", "FINISH", "HEAT_TREAT", "ANGLES", "CN_NUMBER")
                                      vNewNames = Array("TITLE1", "DWGNUMBER1", "USE", "DATE1", "DRAWNBY1", "CHECKEDBY1", "NEXTASSY1", "REVISION1", "SURFACE", "HEATTREAT", "ANGLE", "EN1")
                                      swModel.Extension.CustomPropertyManager(Empty).Add2 "DESCRIPTION", swCustomInfoText, " "
                                      swModel.Extension.CustomPropertyManager(Empty).Add2 "TITLE2", swCustomInfoText, " "
                                      swModel.Extension.CustomPropertyManager(Empty).Add2 "TITLE3", swCustomInfoText, " "
                                          Set swCustPropMgr = swModel.Extension.CustomPropertyManager(Empty)
                                        swCustPropMgr.Delete "DESCRIPTION"
                                      swModel.Extension.CustomPropertyManager(Empty).Add2 "DESCRIPTION", swCustomInfoText, "$PRP:" & Chr(34) & "title1" & Chr(34) & " " & "$PRP:" & Chr(34) & "title2" & Chr(34) & " " & "$PRP:" & Chr(34) & "title3" & Chr(34)
                                      'Get all properties
                                        Next
                                        'Found?
                                          'Already exists?
                                          Next
                                            'Add the new one
                                              'Error: Not added!
                                              Err.Raise AddStatus
                                          Else
                                            'Already exists
                                      Next
                                  Anton Miller
                                  is there a way to get it to open both .sldprt and .sldasm
                                  also, I am not sure if its possible, but could this index into subfolders?
                                      Andreas Killer
                                      Yes, but for that you need much more code.
                                      Download this file and import it into your VBProject (that creates a class module FileSearch).
                                      An example how to search for files is available in the comments in the class module.
                                      https://dl.dropboxusercontent.com/u/35239054/FileSearch.cls
                                      Below is a sample to get you started, untested!
                                      Andreas.
                                      Sub Test()
                                        Dim FS As New FileSearch
                                        Dim ThisFile, Extension, nDocType
                                        With FS
                                          .LookIn = "Z:\"
                                          .FileName = Array("*.sldprt", "*.sldasm")
                                          .SearchSubFolders = True
                                          .Execute
                                          For Each ThisFile In .FoundFiles
                                            'Determine the file type
                                            Extension = Mid(ThisFile, InStrRev(ThisFile, ".") + 1)
                                              Case "sldprt"
                                              Case "sldasm"
                                              Case "slddrw"
                                            End Select
                                            'Open the file
                                            Set swModel = swApp.OpenDoc6(ThisFile, nDocType, swOpenDocOptions_Silent, "", FileError, FileWarning)
                                            CopyProperties
                                            'Close the file
                                          Next
                                        End With
