Hello!
I'm not really good at vb, do anyone see the problem in this:
Dim swFeat As SldWorks.Feature
Dim cwDoc As camworkslib.cwDoc
Dim cwSelMgr As camworkslib.CWSelectionMgr
Dim millOperation As camworkslib.CWMillOperation
Dim setupselected As Object
Dim setup As Object
Dim mirrorAxis As Object
Dim axisbl As Boolean
Set swModel = swApp.ActiveDoc
Set cw = New camworkslib.CWApp
Set cwDoc = cw.IGetActiveDoc
'Method to get the selected setup
Set cwSelMgr = cwDoc.IGetSelectionMgr
Set setupselected = cwSelMgr.GetSelectionsOfType(7, 1)
If setupselected Is Nothing Then
MsgBox "Please select a setup"
'Mirror selected operations
Set setup = setupselected.Item(0)
Set Operations = setup.IGetEnumOperations
For k = 0 To Operations.Count - 1
Set currentOp = Operations.Item(k)
axisbl = swModel.Extension.SelectByID2("MIRROR", "AXIS", 0, 0, 0, False, 0, Nothing, 0)
Set mirrorAxis = swSelMgr.GetSelectedObject(1)
Call millOperation.SetMirrorToolpath(True, False, mirrorAxis, True, False, 0, 0)
Next k
Camworks is an addin that also have the API
When I call millOperation.SetMirrorToolpath , the error say that my object (mirroraxis) is empty
set millOperation = .....
