I have a macro that add a sketch into a drawing, after that i want to ask me where to put a annotation....Select an point on drawing view and after that make a block and finish...
It's possible to do something like that?
thanks
thanks
You can create and open a VB-Userform modeless.
On that form show the user a message that he has to select a point and click on the Ok command button (on the Userform).
When a form is shown modeless the user is able to select something in Solidworks.
In the Click event of the button check if a point is selected. If so exit the form and finish your macro, otherwise throw an error.
Andreas.
Hi Artem,
Interesting example, I've change the output on the from a little to get a better number format:
lblMessage.Caption = "Point is selected: X" & Format(vPt(0) * 1000, "0.000") & " Y" & Format(vPt(1) * 1000, "0.000") & " Z" & Format(vPt(2) * 1000, "0.000")
Y is exact 25, but why is the X coordinate is not zero?
(When I create a line and click on the same point, SW catches the exact middle point of the line.)
(Even if I move the cursor more exactly on the middle point, the X coordinate is never zero, but Y is 25 ever.)
You can see the similar behavior on the vertical line, where X is exact 50, but Y is never zero.
What is missing in the sample code to get the exact middle point of the line?
Andreas.
Hi Andreas,
The method used in the sample is getting the pick point (SolidWorks does the rest to find the snapping one). Not sure why Y is always an exact value, but I think this is just occasion. If you want the coordinate of the point you need to get the pointer to ISketchPoint from ISelectionManager::GetSelectedObject6 and then extract X, Y and Z values. You may need to use sketch transforms if you want a coordinates in the model space.
Artem
Hi Artem,
I don't see how GetSelectedObject6 would be helpful, cause the user can select anything... splines, circles, text, blocks... I understand that I can get the coordinates of such objects, with tons of code...
Let us stay on my simple sample, the line has 3 points: end point on the left, middle point, end point on the right.
How should the code recognize which point I've clicked (the snapping one)?
Andreas.
Hi Andreas,
Once user clicked on the point (including middle point, end points, key points for the spline) or near the point which resulted into the snapping to the point and regardless of what sketch entity was clicked on (line, spline, arc, etc) the selected object will be point (not the segment) so it is possible to extract this coordinate. In case user clicked on the random position within the sketch segment which hasn't snapped to any point the selected object's type would be the corresponding segment and the GetSelectionPoint method can be used in this case.
As the summary: if selected object is point - get the exact coordinate from the ISketchPoint interface
If selected object is ISketchSegment - get the approximate selection point.
The same logic can be applied for the edges and vertices if they needed to be supported.
Artem
I can not see anything in ISketchPoint Interface to get a selected point nor selected object.
Can you show us a sample?
Andreas.
Please take a look at this example: #CODE|Subscribe to the user selection event
Artem
