I am a definite rookie when it comes to the API, and furthermore, to programming. I am SO close to having my macro working, but I am getting an error that I need to debug. This appears to be the final hurdle to getting my macro to function as I intended.
The debug error states: "Object variable or With block not set". Below is the line of code that is causing the error:
I think I know how to set a variable, I'm just not sure which variable to set or what to set it to.
I can include the full macro if it would be helpful.
Thanks in advance!
TextBox1 is an object that has many properties. You want the text property which is the actual text string. Something like this:
TextBox1.Text = <put your string here>
It may require a more full reference to the text box in the form..
Me.Controls("TextBox1").Text = <put your string here>
This is for VBA.
