Hi everyone!
I´m farely new to composer. When I´ve played around with the digger tool I have discovered there´s something I can´t do. So here it is. I´ll try to explain to the best of my abilities!
I´ve created a digger, dragged the Percentage handle to the desired zoom and then I want to use either the X-Ray or Onion skin to higlight something in my graphics. When choosing either of those tools the zoom disappears. I tried to capture this in the snippets shown below.
If anyone knows if it´s even possible for these functions to cooperate I would be grateful for an answer
Thank you!
Meddelandet redigerades av: Rach Pett
Rach,
Your loss of zoom is the way the tool works. You get four options when using the digger, zoom, cutting plane , xray, and onion skin. You can't combine options. The percentage handle controls different properties in each setting and not only zoom. You can however still zoom in on your model using the wheel of your mouse. Then just create your image from that using onion skin or xray. You can then zoom your model out and place the image where desired. The image below was created with xray as I explained above.
Cheers,
Derek
