Hi
Im converted inventor user. And one feature im missing alot, is the oppertunity to mark and open multiple parts from an assembly.
I need it for 2 things.
1. We have details of all parts from a "welding" assembly gathered in 1 drawing. It is a pain to individually open every part, since i need to go back to the assembly after it opens a part.
2. If i have skipped proper naming due to a very early design process, i often open all parts, and go through them one by one. When i have named a part properly (mostly using BoundingBox) i close it down. When all parts are closed down, i know im through the hole assembly.
Thanks in advance =)
You can rename the part on the fly in SW2016 so you really don't need to open it and it would maintain the references. Here is a quick video SOLIDWORKS 2016 Rename Assembly Components on the Fly
Could you explain your current workflow of renaming files when you open then from assembly.
