Hey all,
I designed a box, which contain foam and plastic parts (total of 6 different parts for the box- 3 made of foam and 3 made of plastic) .
The box is built to contain glass ampule (medicine ampule).
I need to check at which the box will start to crack, after assembly.
How can i demonstrate forces on assembled model? i know only to do it part at a time.
Thanks =)
Danielle Awaskar and Itai Meirovich, BGU university.
Make sure there are no gaps and if there are, set them up with contact sets. An assembly is done basically the same way as a part. Apply constraints, apply loads, mesh and run.
Looks like you'll have to do a non-linear analysis if you are playing with foam.
