So after watching the 2016 user interface video, and discovering the new shortcut "move to point" (D), I went looking for it in my SW, and it is NOT in my shortcut menu list. So I reset all my shortcuts to default, at which point it appeared. However then the shortcut "shortcut bar" (S) command disappeared! So I restored my old shortcuts, and the 'Shortcut bar' came back and the 'move to point' disappeared again.
How to I get both commands to work in SolidWorks??
they should both be in the "others" section of the customize> keyboard drop down
you don't have show "commands with keyboard shortcuts" filtered in the show dropdown do you? if so switch to "all commands" to see if you can then find it.
