I have today encountered a situation in which a colleague wanted to specify a maximum radius for a particular feature on a drawing, so he clicked 'Tolerance/Precision and used the top drop-down to select 'MAX'. All well and good, except that on his drawing, the 'MAX' appeared in lower case.
I did the same on another drawing and the 'MAX' appeared in upper case.
My draughting training, all those years ago, taught me that everything on a drawing should be upper case, so I believe mine is correct and my colleague's is incorrect.
The question, however, is this:
How is it different between the two drawings?
The follow-up question is:
How and where is the format of the 'MAX' suffix set?
I can't find it in the help.
SW2014
SP5
John
I couldn't find an override for it--not to say there isn't one. All of the drafting standards except ANSI show 'max.'. ANSI shows 'MAX'. So the only way I could figure to do it is to set the drafting standard to ANSI and override all of the settings to make it look like ISO. (I'm assuming you want ISO). This is a hack--it seems like there should be a cleaner way.
On the other hand, this makes me suspect that ISO should be lowercase--I don't know ISO very well..
