Hello I have not been able to figure this one out after hours of pondering the issue.
I am creating an undertray which includes a tunnel from front to end and the diffuser at the end of the undertray. In order to have the file run through a cfd program, I need to be able to hollow out the tunnel. The attach image shows where the cut will start (first solid blue square) and then follow the purple guide line and end at the dotted blue line. The thickness of the material will be 3/16 of an inch. How do I make this cut? Lofted cut seems not to be working. I can attach the file if need be.
Thanks in advance for the help, this is very frustrating.
It shelled as easy as pie for me (using SW2004). I selected the bottom surface, and the two ends as surfaces to remove:
The tunnels were extruded up to the red surface below, before the shell command.
