Read Cosmetic Thread
Hrituc Alexandru Jan 8, 2016 8:05 AMHi,
How can modify this code to run on solid part not for drawing?
i try to modify it and it's not working
2016 SOLIDWORKS API Help - Get Entities Attached to Cosmetic Thread Example (VBA)
Option Explicit
Dim activeDocument As SldWorks.DrawingDoc
Dim pAnnotation As SldWorks.Annotation
Dim selType As Long
Dim entityCount As Long
Dim SelMgr As Object
Dim entitiesArray As Variant
Dim attachedEntity As SldWorks.Entity
Dim selView As SldWorks.View
Dim annotType As Long
Dim attachedEntityTypes As Variant
Dim i As Long
Dim edgeParams As Variant
Dim edgeRadius As Double
Dim faceParams As Variant
Dim faceRadius As Double
Set activeDocument = swApp.ActiveDoc
If (activeDocument.GetType <> swDocDRAWING) Then
Exit Sub
Set SelMgr = activeDocument.SelectionManager
selType = SelMgr.GetSelectedObjectType2(1)
If (selType = swSelDRAWINGVIEWS) Then
' Get the selected drawing view
Set selView = SelMgr.GetSelectedObject6(1, -1)
If (selView Is Nothing) Then
Exit Sub
' Get first annotation in the view
Set pAnnotation = selView.GetFirstAnnotation3
' Loop through every annotation in view
While (Not pAnnotation Is Nothing)
' Get the type of annotation
annotType = pAnnotation.GetType
' For each CThread, get radius of attached entity
If (annotType = swCThread) Then
' Get attached entities
entitiesArray = pAnnotation.GetAttachedEntities
attachedEntityTypes = pAnnotation.GetAttachedEntityTypes
' Get number of attached entities
entityCount = UBound(entitiesArray) + 1
' For each entity attached to this CThread
For i = 0 To (entityCount - 1)
' Get the individual Edge or Face2 object
Set attachedEntity = entitiesArray(i)
' If attached entity is an edge
If (attachedEntityTypes(i) = swSelEDGES) Then
edgeParams = attachedEntity.GetCurve.CircleParams
edgeRadius = edgeParams(6)
swApp.SendMsgToUser "Cosmetic Thread Edge Radius = " + Str(edgeRadius)
' If attached entity is a face
ElseIf (attachedEntityTypes(i) = swSelFACES) Then
faceParams = attachedEntity.GetSurface.CylinderParams
faceRadius = faceParams(6)
swApp.SendMsgToUser "Cosmetic Thread Face Radius = " + Str(faceRadius)
Next i
Set pAnnotation = pAnnotation.GetNext3
Wend
Else
swApp.SendMsgToUser "Please select a drawing view containing cosmetic thread annotations"
I have the same question (0)
