I have made a solid part model which has a curved surface.
I could select rest all other surface in this model but expect the curved surface.
Attached image for reference/
However if i click over the surface. Faces/ surfaces below the curved surface is getting selected.
But if section at that surface. i could select( click on to ) the surface.
Why is that i could not able to select the surface which i want. ?
Hi Sanjay,
Sometimes closing and re-opening part does the trick. I f you have not tried it, try it.
