Finding unit vector for each selected line
Question asked by Thomas Bryant on Jan 6, 2016
Latest reply on Jan 20, 2016 by Thomas Bryant
Thanks to some assistance from Ivana Kolin in the thread below, I was able to calculate a unit vector from a line and put the results into an Excel file from there.
The next step in the macro is to select multiple lines and have SolidWorks put all the calculations of the unit vectors in one message box and one Excel file (I would prefer not to have multiple popups). I would prefer to get results from only the lines that the user has selected, but all lines in the sketch would be ok too.
Calculate unit vector from a line?
Here's what I have tried so far:
Option Explicit
Sub Main()
    On Error Resume Next
    Dim swMathUtil As SldWorks.MathUtility
    Dim swSketchLine As SldWorks.SketchLine
    Dim oMyLine As Object
    Dim oMathVector As SldWorks.MathVector
    Dim oUnitVector As SldWorks.MathVector
    Dim vPt1 As Variant
    Dim vPt2 As Variant
    Dim dArr(2) As Double
    Dim i As Long
    Dim j As Long
    Dim dArrUnit As Variant
    Dim xlApp As Excel.Application
    Dim xlWorkbook As Excel.Workbook
    Dim swStartPt As SldWorks.SketchPoint
    Dim swEndPt As SldWorks.SketchPoint
    Dim NumberOfSelectedItems
    Dim swSelBody As SldWorks.Body2
    If Not swApp Is Nothing Then
        Set swModel = swApp.ActiveDoc
        Set swMathUtil = swApp.GetMathUtility
        If Not swModel Is Nothing And Not swMathUtil Is Nothing Then
            Set swSketchLine = swSelMgr.GetSelectedObject6(1, -1)
            If Not swSketchLine Is Nothing Then
                Set swEndPt = swSketchLine.GetEndPoint2
                Set swStartPt = swSketchLine.GetStartPoint2
                dArr(0) = swEndPt.X
                dArr(1) = swEndPt.Y
                dArr(2) = swEndPt.Z
                vPt1 = dArr
                vPt2 = dArr
                dArr(0) = swStartPt.X
                dArr(1) = swStartPt.Y
                dArr(2) = swStartPt.Z
                dArr(0) = vPt2(0) - vPt1(0)
                dArr(1) = vPt2(1) - vPt1(1)
                dArr(2) = vPt2(2) - vPt2(2)
                NumberOfSelectedItems = swSelMgr.GetSelectedObjectsCount2(-1)
                For j = 1 To NumberOfSelectedItems
                ReDim swSelBody(1 To NumberOfSelectedItems)
                Set oMathVector = swMathUtil.CreateVector(dArr)
                If Not oMathVector Is Nothing Then
                    Set oUnitVector = oMathVector.Normalise()
                    dArrUnit = oUnitVector.ArrayData()
                    MsgBox ("Line vector is " & dArr(0) & "i + " & dArr(1) & "j + " & dArr(2) & "k" & vbCrLf & "Unit vector is " & dArrUnit(0) & "i + " & dArrUnit(1) & "j + " & dArrUnit(2) & "k"\n)
                    Set oUnitVector = Nothing
                    'set array here
                    oUnitVector.ArrayData(dArrUnit(0),dArrUnit(1),dArrUnit(2))
                    Set oMathVector = Nothing
                Next j
                Set oMyLine = Nothing
                Set swSelMgr = Nothing
            Set swSketchLine = Nothing
        Set swModel = Nothing
        Set swMathUtil = Nothing
    'get the results into excel
    Set xlApp = CreateObject("Excel.Application")
    xlApp.Visible = True
    Set xlWorkbook = xlApp.Workbooks.Add
    With xlWorkbook.Worksheets(1)
        .Cells(1, 1).Value = "i"
        .Cells(1, 2).Value = "j"
        .Cells(1, 3).Value = "k"
        .Cells(i + 2, 1).Value = dArrUnit(0)
        .Cells(i + 2, 2).Value = dArrUnit(1)
        .Cells(i + 2, 3).Value = dArrUnit(2)
    End With
    Set xlWorkbook = Nothing
    Set xlApp = Nothing
Thanks for any assistance.
