Hi all,
I think it's really simple, but can't get it to work. Just stepped into the world of macro's.
I downloaded and edited a few examples and wish to make them work within my models. I now created a user form to change dimensions successfully.
What I can't get to work, is changing global variables. What line of codes do I have to insert?
For changing the dimensions I use a variable from the userform and the following line of code:
boolstatus=Part.Extension.SelectByID2("name@sketch@location","DIMENSION", xx,xx,xx....)
Part.Parameter("name@sketch").SystemValue = dblVariable
In this case, 'Part' is the active document.
Pretty simple and straightforward to me. Is there any simple line of code to change Global variables within the equations manager?
Thanks!
The codes I've posted above assume that you already have a global variable.
For e.g. add a variable A with any value and then run the codes. The value should change to 5.
