I have a very large assembly I am working on, so I spend most of my time in Large Assembly mode with all lightweight components. However, every time I open the model or one of its sub-assemblies for the first time (such as first thing in the morning when I begin working), I get a whole bunch of rebuild errors, where none were before when I saved and closed the model.
I've found the source of the errors to be a few sub-assemblies buried deep in the model that have parts patterned using Sketch Driven Component Pattern. Selecting the seed part of the pattern and doing a "Set lightweight to resolved" command clears the error and resolves the issue. I don't want to have to do this every time to clear the error, so I tried setting the pattern to refer to different features of the part (first the origin, then a reference geometry point, then a 3d sketch point), but each time, switching the part back to lightweight made the error re-appear.
Is any way to avoid having to open the sub-assembly and set the part to resolved every time? Any other work-around to this issue that will be permanent? I'd like to set the part to never load lightweight, but all I can find are the general solidworks settings to "Automatically load components lightweight" and "Always resolve sub-assemblies", etc. but nothing that applies only to a specific component.
Not the answer you're looking for but I have been having a similar problem with lightweight in a large assembly. When opening the assembly it loads in lightweight (Faster yes) however 2 sub assemblies of an assembly are floating out of place. When set to resolved from "lightweight" they snap back into place with their correct mates. I have changed the way these components were mated in every way possible trying to resolve this even adding mates while they are in "lightweight" mode (SW help says this is possible). From what I've read this seems to be a problem with the way lightweight loads the model. The "SW Help" section says that lightweight suppresses or ignores certain features or datums making the components easier to load. This is great but if it is suppressing features or sketches being used for patterns and assemblies its useless and time consuming to set each thing to resolved. (your question is also the only thing i've been able to find on google describing this problem)
