I would like to be able to add a short note to the trend journal after each iteration. Is there any way to do that? This way I can keep track of any changes I made to the model without having to have a separate document. However, if you open up the Trend Journal document and add notes, the notes will be gone when you run the nest iteration. Is there a handy way to keep notes in a Simulation file as you go?
It is not possible to do it through SW, you will have to create a seperate Journal. Only option is to use the report function, and afterwards edit multiple reports to make one document.
