I have a multibody sheet metal part inside an assembly, and a drawing which contains:
- A BOM, indented, With detailed numbering, detailed cut list checked
- All sheet metal bodies in a flattened state, in separate views.
- A Balloon With item number for each view/body.
The item numbers display as asterisks for the flattened bodies.
If I un-flatten the bodies, they show correct item number.
Any solutions for this?
If I use a weldment cut list instead of BOM, it also shows correct numbers. But I want to use a BOM, so I can have all parts in one table.
--svesjo--
