how do I make Revolve Boss to meet an 8 sided, angled surface.
Attached is an assembly the part I need is sketched in on the Front Plain.
The inside part is round, outside part has 8 sides, the Blue sketched part needs to fill between them so it's touching the round surface and all 8 sides.
I should have started with insert part so I could save it as a separate piece of open cell foam that will be glued in.
Thanks, Jerry
hei'ya Gerald,
here's my take on your part
produce the part from sketches
with added planes, intersection curves
and extrude cut
probably could do it a couple of other ways
just a quickie not fully defined
hope this helps- have a good'n kelef
