I lost the command manager and I cant find how to put it back on the top of my screen. Any ideas?
Hi Casey,
You can use the "View-Workspace-Default" menu choice to restore the commandManager position.
Best Regards,
John
Do you have this checked under Tools > Customize
If yes and if you can see the command manager flying around then double click on the command manager and it will set itself into the last position. Else you can drag and drop it on this arrow
You should also keep your Copy Settings Wizard file handy to bring back your settings.
Hi Casey,
Best Regards,
John
