Hello, doing some play with the fatigue feature.
Im having some issues with the loading events, ive done the static (looks good), and ive done a fatigue fully reversed (looks good). When i do a zero based, it doesn't find any change in results, ie it is showing as nothing is happening (its one solid color).
(attached)
Because in both cases you use a SN curve based on R = -1 in the material properties, so you end up with the same result.
Janko Stellaard
Cadmes BV
The Netherlands
