Rename Fillets
Question asked by Aj Bosma on Jan 4, 2016
Latest reply on Jan 4, 2016 by Mike Spens
Is it possible to "remodel" this macro so that is does rename all the fillets in a part?
Option Explicit
Dim swFeatMgr As SldWorks.FeatureManager
Dim vFeatures As Variant
Dim sFeatureNames() As String
Dim swFeature As SldWorks.Feature
Dim swChamfer As SldWorks.ChamferFeatureData2
Const Pi As Double = 3.14159265358979
Dim Digits As Long
Dim i As Integer
Dim k As Integer
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then Exit Sub
If Not swModel.GetType = swDocumentTypes_e.swDocPART Then Exit Sub
Set swFeatMgr = swModel.FeatureManager
vFeatures = swFeatMgr.GetFeatures(False)
k = 0
Digits = 3 'Number of digits of angle to be shown in feature name
'Set a temporary name in order to avoid possible naming conflicts
'this might consider to be not necessary. Remove or comment the code if you want to disable it.
ReDim sFeatureNames(UBound(vFeatures))
For i = 0 To UBound(vFeatures)
    Set swFeature = vFeatures(i)
    If swFeature.GetTypeName2 = "Chamfer" Then
        Set swChamfer = swFeature.GetDefinition
        k = k + 1
        swFeature.Name = "Chamfer_temp_name_" & k
    sFeatureNames(i) = swFeature.Name 'Load all feature names into array to speed things up
Next
'End of setting temp. names to chamfers.
        swFeature.Name = SetName(swChamfer.Type) 'Assign name to feature, using function SetName
        sFeatureNames(i) = swFeature.Name 'Update array with all feature names.
Next
Private Function SetName(ChamferType As Long) As String
Dim i As Integer
Dim k As Integer
Dim sName As String
Dim sNameTemp As String
Dim iswFeature As SldWorks.Feature
Select Case ChamferType 'Depending on chamfer type, get different data and set the feature name different.
Case swChamferType_e.swChamferAngleDistance
sName = "Chamfer " & swChamfer.GetEdgeChamferDistance(0) * 1000 & "x" & Round((swChamfer.EdgeChamferAngle * (180 / Pi)), Digits) & Chr(176)
Case swChamferType_e.swChamferDistanceDistance
sName = "Chamfer " & swChamfer.GetEdgeChamferDistance(0) * 1000 & "x" & swChamfer.GetEdgeChamferDistance(1) * 1000
Case swChamferType_e.swChamferEqualDistance
sName = "Chamfer " & swChamfer.GetEdgeChamferDistance(0) * 1000 & "x" & swChamfer.GetEdgeChamferDistance(0) * 1000
Case swChamferType_e.swChamferVertex
sName = "Chamfer " & swChamfer.GetVertexChamferDistance(0) * 1000 & "x" & swChamfer.GetVertexChamferDistance(1) * 1000 & "x" & swChamfer.GetVertexChamferDistance(2) * 1000
End Select
k = 1 'Since first feature is no.1.
Restart_:
If k > 1 Then
    sNameTemp = sName & " (" & k & ")"
Else
    sNameTemp = sName
For i = 0 To UBound(sFeatureNames)
    If sNameTemp = sFeatureNames(i) Then
        k = k + 1
        GoTo Restart_:
    ElseIf sNameTemp = sFeatureNames(i) Then
        k = k + 1
        GoTo Restart_:
Next
If k > 1 Then sName = sName & " (" & k & ")"
SetName = sName
End Function
