The New Sliding Mesh Technique from 2015's Flow Sim is well good for rotating regions like fan/pumps, would it also hold good for Non-rotating regions also ?
And, inorder to capture the video of rotating solid (fan blades/impeller) inside in post processing ?
Cheers,
AJ
Hello Ajay,
I am still with SW2014 and have not tried the sliding mesh capabilities but from my general knowledge and experience there should be no reason to use sliding mesh in translational sliding between two fluid zones. You do not need sliding mesh when a flat solid wall is moving along it surface. In that case you should use moving wall boundary condition and assign a proper vector for the moving velocity (the vector MUST be in the plane of the flat wall !)
Regarding the visualization of the rotating rotor, please provide more details of the issue you have encountered. Different
type of Flow Simulation results animations are possible.
