How do I use smart dimensions to find the distance between two mounting holes?
Mark A
Mark A
hei'ya mark,
you need to edit the sketch
of these features-
at the moment this is
only a referance dimm. in the model
find the feature in the feature tree first-
expand to see the sketch-
and edit the sketch-
then dimm. between holes-
and other dimm. to locate position
of the holes
edit:
of course you could just>
double (LMB) click on the feature>
this will show dimm. if any>
and edit if shown by clicking on the dimm.
if not select smart dimm. tool and dimmension and confirm
hei'ya Mark,
select the smart dimm. tool
select first hole (LMB) in graphics area,
then the second hole (LMB)-
select the property manager
and set the parameters
hope this helps- have good'n kelef
