I'm trying to draw a centerpoint arc slot but whenever I change one parameter another one changes automatically. I had this problem with other entities also but somehow attained the desired parameters by constantly changing the parameters manually until they wouldn't change automatically anymore. I got lucky, but my lucks run out. Can this be turned off?
This is how I want the slot:
radius = 35mm
angle = 45deg
thickness = 10 mm
Thanks.
Are you trying to control the slot by inputting values in the property manager?
If so, try adding dimensions to your sketch instead.
