Recently I have been doing some square routing for some hot air system in the old way. And i got a part from some mechanics workshop. I would like to know if there is a way to recreate that part in Solidworks. They made this part with some manual benders so its very crafty. bottom part is bigger. Exactly I would like to know how to do this piece of sheet in the picture (side) (no pun intended).
thanks for your kindly answers
This is how I believe John envisioned this and if so he deserves all the credit for making me think some more about this. The side has 3 planer surfaces, thickened, relieved, then Insert Bends. Not too shabby but the front wrap would have to change slightly and the back just a tad (or possibly tack and hammer the curves) since the surfaces are flat. Between the lofted method and this method you should be able to get some ideas. Just use the SM flatten tool to see the flat pattern.
