Questions on adding datum references to radial dimensions
Question asked by Sarah Dwight on Dec 28, 2015
Latest reply on Dec 28, 2015 by Jeremiah Feist
First is it correct to add a datum reference to a radial dimension?
Second which way should it look?
If I select the dimension then click to add datum feature it gives me datums attached to the line, like H and J.
If I select the dimension second, once I am in the datum feature tool it adds the datum below the text, like C and G.
How can I fix the overlap when adding to a bilaterally toleranced dimension, like G?
How can I fix the alignment on line as datum is attached to midpoint and I am unable to reattach it or change relation?
