Electrical Routing API
Question asked by Rick Hombsch on Dec 23, 2015
Latest reply on Dec 28, 2015 by Mike Spens
I am trying to write a macro that runs through all components in an assembly and pulls out some information from all electrical routes. The info I am trying to pull is then given name of the route as well as the length of the route.
I have not found any info on accessing this information from a macro so any information would be helpful.
Rick
Set Part = swApp.ActiveDoc
ConfigNames = Part.GetConfigurationNames
'Determine How Many Configurations Part Has
LastConfig = UBound(ConfigNames)
For k = 0 To LastConfig
    'Set Config to ith Configuration
    Config = ConfigNames(k)
    Part.ShowConfiguration2 (Config)
    Name = Part.GetTitle
    'If assembly
    If InStr(1, Name, "SLDPRT", 1) = 0 Then
        Component = Part.GetComponents(False)
        NumberOfComponents = UBound(Component)
        'For all components in assembly
        For i = 0 To NumberOfComponents
            ComponentName = Component(i).GetSelectByIDString
            Suppression = Component(i).GetSuppression()
            If Not Suppression = 0 Then
                Dim SubComponent As SldWorks.ModelDoc2
                Set SubComponent = Component(i).GetModelDoc2()
                ComponentType = SubComponent.GetType
                CompConfig = Component(i).ReferencedConfiguration
                PreferedPart = SubComponent.CustomInfo2(CompConfig, "PreferedPart")
            Else
                ComponentType = 2
            Name = Replace(Name, ".sldasm", "", 1)
            ComponentName = Replace(ComponentName, "@" & Name, "", 1)
            'Insert Code Route ID Code Here
        Next i
Next k
